Hey all, sorry if this is off-topic, but I need some quality input. Got a front mounted pump on my IH that has a 7/8 13 spline input shaft. The pump is driven by an adapter shaft that bolts directly on the crank pulley. On the pump end, there is a splined coupling that wears out after 2 solid hours of work. I cut the adapter shaft in the middle and installed a flex coupling to correct for the misalignment, but the splines on the pump shaft are already somewhat damaged and because of the play in the connection and the pump shaft being a lot harder than the coupling material, the internal splines get shaved off regularly. What can I do about this, short of tossing the pump? Can I just pin or bolt the coupling to the pump shaft to eliminate any play between the splines and let it be taken up by the flex coupling like it's supposed to? Appreciate any advice.
