Hydraulic pump
Dunk
(quoted from post at 20:32:01 04/29/10) While trying to fix the no lift problem I was told the safety valve is a common problem so I bought one.I am trying to replace the relief/saftey valve in the pump. The diagrams I have looked at, and the part I have does not look like what is in the pump. The fluid had water in it so I drained all the fluid to get a better view. Does anyone have pictures or diagrams to help with an ID?
Hobo has a how to for you, but I hear that the newer ones don't look like the older ones.
http://www.theviperr.info/hobo_dnn/Default.aspx?tabid=114
Yep, new ones look slightly different than the old ones, but there is only one place it will fit, and that is just above the intake and exhast valves.
Thanks for the pictures. The valve in the picture looks the same as the one I bought. The area where the wrench is in the pictures has a stem coming out (starter side) which seems to move a pivot. Just by looking I don't see anything that looks like the valve end on the one I bought.
(quoted from post at 20:48:41 04/29/10) Thanks for the pictures. The valve in the picture looks the same as the one I bought. The area where the wrench is in the pictures has a stem coming out (starter side) which seems to move a pivot. Just by looking I don't see anything that looks like the valve end on the one I bought.
Another of Hobo's pics, see the hex?
