Hydraulic remotes
doneb
I'm wanting to use the hydraulic remotes on my 1959 881.I need the male half (poppet valve) to use on the implement hose. The parts manual gives the P/N as D3NN8964A which brings up nothing when searching online. Can someone tell me what size the valve is? Tried measuring the female half and it appears to be larger than 1/2". Not sure. I see item 119129 on this site and want to make sure before ordering that it will work. The female half on the tractor has the info - The Bruning Company Lincoln Nebraska- and nothing else. Any help would be appreciated.
Ford normally used the pioneer standard coupler, avalible here, TSC and most any place that sell tractor hydraulic parts
Posting a photo of your coupler could help
This is the remote set up. The opening on the female coupler is about .935. Down inside where the nipple is looks to be about 5/8 " or larger.
When mounted correctly,, those look like the upgraded connect under pressure / high flow female versions that should be mounted by the collars not the body. The ones that I have use the standard 1/2 inch male, but prefer the high flow tips with the points and not the common balls. These were used on the 6600 series and mine were an orb female on the hose side. On my 6700 the little tiny tips in those female connectors,,,,were bad about breaking off if abused. And these were like 80 bucks apiece back in the '80s. However I could be wrong as yours have the custom name on them. hope this info helps??
It does help. I've ordered the tipped ones you have described so I'm certain now I've chosen the right ones. Thanks.
