hydraulic retrofit
IHCC51
Have a 1951 Farmall C with touch conrol hydraulics. Used the ports on the left side of the hydraulic cylindar and valve unit to power a home made 3 point hitch. It works but under a load I have to engage both the original touch control lever and my added control valve, making it a 2 handed operation.Is there a way to transfer all hydraulic power to my added valve?
thanks to anyone who can help!
I believe that the other valve may have an open center and both valves have to be activated for the pressure to be engaged. (or basically all the fluid is running through the path of least resistance) I could be wrong.
