Hydraulics bind up?
hayray
I have been having this problem with my White 2-105 while operating the gate on my NH BR 730 baler. Hook up the machine, door opens and closes no prob., get to the field make the first bale and go to eject and then the door opens part way and stops. One hydraulic hose will not release pressure, I have to undue the male end to release pressure. I then switch to the other set of remotes and then bale for a while and the same thing happens with the same hose coming from the baler, so I switch back to the other remotes. Is this a baler or tractor issue?
Check the quick connects on the hoses from the baler,sounds like one is getting worn out and intermittantly not flowing oil.
I have a similar issue with my baler. One hose to the cylinder that moves the thrower side to side leaks a little and once in a while the cyl wont move one way. If I idle the tractor down and move it back and forth it starts to work again. Wierd. I suspect the leak is causing the problem because other implements do not do this.
I intend to fix the leaky hose one of these days to see if the issue goes away.
Do you have any leaks?
I'd be looking at the baler. That 2-105 has open center hydraulics,so should be getting good pressure out there.
My John Deere hydra push spreader is the only thing I have around here that does that. Frustrating as all get out. Like you said,intermittent. Only does it if I bring the floor all the way ahead. If I leave it back just a little it's alright. Like you said,it will stiffen one hose up and I have to wedge a cresent wrench between the tip and coupler to get it out,then bang the tip on the drawbar to get the pressure to release. It doesn't do it on my 1850 with closed center hydraulics so much as it does the 2-135 though. I know it has to be in the spreader though,that's the only implement that does it.
