Hydraulics not working
Ted Lewis
I just put new seals and o-rings in the Hydraulic pump on my Kubota b7100d. I changed the hydraulic fluid but now the arms on the 3-pt will not lift. Is it possible that there is air in the system? If so how do I bleed it out? Thanks for your help.
I would crack the return line loose at the pump, without it running, and make sure there is oil there. I have seen pumps not prime if they are not oily enough.
You were right, not a drop when I open the return. Now to figure out how to get it to prime. Thanks for your help.
