hydraulics on 454 int
FRANK Foster
the 3pt will not operate the steering and pto does also has aux. lines.Fluid is full and clean the tractor has been sitting for about 2 years the top part was susposedly rebuilt. this is a 3 cyl diesel.read on here about bleeding will try that.
Hi Frank, if steering, pto and brakes work but no 3pt or aux outlets then the splitter valve is stuck in the MCV. The splitter valve is supposed to split 3 GPM for PS, PTO and PB and 6 GPM for 3pt and aux outlets.
Sometimes the splitter valve can be unstuck by activating the aux outlet lever until you hear the hydraulic relief valve squeal or turn the steering wheel to the max in either direction until the hydraulic relief valve squeals. This hydraulic shock to the system sometimes frees the stuck splitter valve.
BTW the 454 with 3cyl German Diesel is a good utility tractor and engine will run many hours with proper maintenance.
Always be sure to release parking brake before driving tractor. The chewed up parking brake band causes many hydraulic system problems on these 74 series tractors.
JimB
