Hydraulics on a 6600
Derekj
Hi All, I have 4 lines out back. Facing the tractor from the rear, the left 2 are operated with the lever under the seat that you move forward and back with your right hand. I have a FEL that plugs into them and have to tie the lever to the rear with wire in order for me to use the 2 levers mounted on the fender to operate the bucket tilt and to raise and lower it. I have just hooked up my batwing and would like to know what operates the 2 lines on the right? Thanks.
Follow the hoses to see where they go. If they connect to the same valve block as the other rear remotes, then there should be a second handle next to the first one under the seat, but that handle may be missing.
Thanks for the replies , it does connect to the same body and looks like the pin broke off where the handle connected and another screw was installed where the ball for the lever should go. I am going to remove the plate to install a new "plunger" and remove the bolt for a new ball, then new lever. Thanks for the advice.
