CARMINE3
Removed the backhoe from an old ford because the lines are leaking and would like to repair but there are three lines, two small and one large. Would like to pull the tractor away in order to make repairs but figured the lines cant be left open.
Could use some advice
Thanks Carmine3
Do not just plug them, you could destroy your pump. You need to figure out where the other end of each hose goes and post that info. Without that it is just guessing which hose does what and how to hook things up to let you separate the tractor and hoe properly. JMHO
