R. Gibson
I have a problem with the hydraulics on the 1947 Ford 9N that I have. THe problem is that when it is with the PTO engaged, the front of the shredder can be raised up to 3/4 of my desired height. After what seems like only a few minutes it drifts the shredder into the PTO shaft or ir drops all the way to the ground. Is there something I can do to keep it where I would like it to stay at? Or is theere a major problem with the linkage of the hydraulics? Please help, thanks.
You could set up 2 stop chains to keep the draw bar at the height that it needs to be, each chain from the sides of the 3rd point to each far hole on the draw bar. Remember to lock the lift handle down
The internal cylinder and or the valving connections are leaking down. It would require pulling the top rear cover to repair, or use the chain system described below. The chain or bar method is stout, but limits other uses unless made with pull pins to unhook it when not needed. JimN
At the present time there are two lengths of chain bolted to the gear box on the shredder, with a length of flat steel attached to the ends of each chain. I have held them at full length and they do not come close to the 3 point PTO at all. Are these the links that you referred to to keep it in a locked position. If so where would I need to connect them to.
Thanks again for your help. Have a great Thanksgiving to you all.
The stop chains that are on my dad's 2N are bolted to the bottom of the 3rd point mount. From there he connected them to the opposite holes of the draw bar. This gave a "triangle " effect and held the draw bar wherever you set it, so you could run the PTO and not worry about the bar dropping. (just make sure that the lever on the r/side of the seat is locked in down position)
