hydro fluid
got a 3020 deere with syncro and a 1070 case with power shift-now can i use the same hygro oil in each?i do and will be changing implements on both tractors. And if so what are the thoughts on using a universal HY Guard oil that the local parts store sells-(Champion)
let er rip
thanks Bob
Fluid must meet John Deere specifications and be wet clutch compatible. If no compatibility with wet clutches, the clutches (and Brakes on the 3020) will be torn to shreds.
It MUST be a fluid capable of being under hydraulic pressure and wet clutch compatible.
Make sure you change the filters on both tractors and clean their trans screens. Make sure there is no crappy oil in your implement cylinders too.
