hydrolic control vaulve
Work man
My hay forks went into the ground. I think I busted control vaulve to the hyrolics. Need print out of over vew of hydrolice box area. Or info of it. Hydrolic fluid went every were both sides of tactor and out the top of were you check the hydrolics. Interntional tractor 806 hydrolic box under seat.
Take the seat off and the cover. You probably just ruptured a hydraulic line.
Allan
More than likely you just busted a hose or pipe going to the lift cylinders, clean it off and look for leaking oil.
Walt
