Hydrostat Problem
JDB
My Cub Cadet 2086 will not maintain speed. I will set it to a speed and within a short time it starts going faster and faster until it is full speed ahead. It it a hydrostat problem or a linkage problem? I"m open to suggestions.
Does your hydrostatic shifting lever move when your tractor speeds up? If it does you may need to tighten to friction spring on the shifting lever that should be beneath the tractor on that lever. Hal
If the Hydro Lever moves, then the Friction Nut on the pivot point needs to be tighten to 10" pounds of resistance.
