hyds not working
starman
I have a ford 1700 that I changed the trans/hyd oil and the filter/strainer now none of the hyds will work, is there a reason that it can lose suction or do I have a bad pump. before I did all of this the hyds worked until it warmed up, then they they would quit working
thanks
If the Strainer/Filler is clean,you might try bleeding the air out of the hydraulic pump.If no bleeder plug,crack the pressure line loose at the pump.If it works again till it gets hot then quits the pump may need rebuilt or replaced.
The working part time was before I CHANGED OIL AND FILTER that is the reason I CHANGED, sorry cap lock keeps sticking
Not getting any responces, surely some one has an idea what the problem is, maybe need to crack open the suction line and bleed it
thanks
