I-20 or 10-20
Oldiron29
Guys I beleive this to be an I-20 would like other opion. Tag has no model Brake handel looks I-20 on Ebay 130842526892
Your thoughts please. oldiron29
im going to say its been put together form parts at some point. may be both 10-20 and model 20 goodies there
serial number denotes a 1925 model. it does have the early style manifold and exposed gov linkages to the carb but the gov housing is square to say mid '27 or newer. it also has an oil filter which would be mid '29 or newer block.
rear rounds have the hole in the hubs for brake drums but absolutley no hardware fo the external contracting band type brakes which they used.
it also appears to have two different axle quills but neither of them look like they have the bosses on the back for a pintle hitch to bolt on.
does have the belt pulley delete clutch cover though
dunno
(quoted from post at 14:35:20 01/30/13) The serial plate with KC prefix indicates a 10-20.
if i remember correctly the first couple years they made 10-20's the industrials used the same serial prefix as the ag tractors and numbers ran concurrent.
i wanna say that was only '23 and '24 model year though. after that the had IN and/or IND prefix
