I did something stupid
gblj
I have a 2014 Kawasaki mule, I was filling it with gas and wanted to see how close it was to the top, I took a half inch dowel and stuck it in the gas tank, well the tank is deeper than I thought and it slipped and now it's in the tank, I called the Kawasaki dealer to see if it would be a problem they said NO, what I want to know is what effect gas will have on the dowel.
What's the worst that can happen? It will disintegrate and block the outlet. Kind of like pebbles in a tank. Someone did that to my tractor once. Real PIA to remove every to dump out the tank. Of course it was full of diesel fuel.
Vito
It will smell like gas forever. It’s your new fuel gauge. Attach a string to the top for the next time.
nothing nothing nothing will happen, if it worries you remove the tank and get it out. its a common sense thing.
Depending on which tank you have.
Worse case is the dowel can mess with the fuels float gauge lever in the tank.
If you have an in tank fuel pump. Just remove the pump, reach in and retrieve the dowel rod. Be a good time to change the fuel pump screen while you have it out.
I will last intact for a very long time just floating in the gas.
My Mule is a little newer, but on mine you can pop the seat bottom out, remove the in-tank pump, and then reach your hand in there and pull it out. I was inside my tank a couple months ago, tank had a lot of trash in it and I got in there and cleaned it out.
The dowel will probably hold up longer than the o-rings, diaphragms and fuel lines, especially on an already 11 or 12 year old fuel system. I would wait to pull the wooden dowel out until you service the rest of the fuel system. The dowel will be swollen oversize and will stink like fuel for years so I would not reuse it except as kindling.
I'll bet you won't do that again. Stan
Well I got the stick out of the gas tank, thanks for all your suggestions, a special thanks to RobCons and the Jaws of death, it took two Jaws of death one to lift it to the fill tank hole and another to grab the end and pull it out.
It is a nice stick!!!!
