I feel a dentist
SVcummins
Got paid 431$ for not even 5 minutes work !
I was pulling in the pro farm class against tractors with four times the horsepower of this one if not more I took fourth place . I don?t think the duals helped but they look good . I want to try it next year and see what happens
I remember watching a pull where a bunch of the souped up pulling tractors couldn't do a full pull. In drives an old Deere that was straight out of the field. He hooked up and did a full pull plus. They changed the weight speed, and he did it a second time. When he did the third pull he came within about 10 feet of another fill pull.
It all goes to show that the amount of HP isn't nearly as important as whether or not you can put it to the ground.
(quoted from post at 23:10:59 08/23/19) I think 2 gallon total is a high figure. Only burn 2 an
hour wide open on that plow
I think 2 gallons of fuel per hour with a powershift trans such as your 3020 is not even close to Nebraska test.
Well the whole thing only took about 30 minutes
including the drive to the fair and back so 2 gallon is
still a high estimate.
1.5 to 2 per acre not hour . Burned 1.5 drilling .
16 foot John Deere tool carrier with 16 inch
wheatland sweeps and 16 foot John Deere lz1010
unit hoe drills
