coloiron
I just purchased a I H 185 tractor with 3 pt and a belly mower I am unable to get the mower from running. It doesn't make any difference
if the mower is up or down.
Thanks for your help
The likely issue is the drive clutch being internally frozen. the plates shown can be sticking together keeping it turning when shut off. another possible issue is the control mechanism. (different page in the parts manual attached link. Jim
parts
No, it makes no difference. Not real familiar with that machine, do you basically flip a switch to turn on the PTO? If so the overrunning bearing in the magnetic clutch unit has probably locked up. When the magnetic clutch is not powered the bearing allows the shaft that powers it to spin and the pulley for the belt to be stopped.
Edit: Sorry, Jim and Jim have me on the straight and narrow now. I forgot I could access the online parts catalog JAN linked to see the configuration. I will send you an email with some additional information.
This post was edited by used red MN on 08/31/2023 at 11:57 am.
The 185 does not use a magnetic clutch. It uses a completely mechanical multi-disk clutch. It is engaged by a rotating cam assembly. The multiple disks are what Jim was referring to sticking together. There could also (probably) be some failure in the cam mechanism that is keeping it from releasing the pressure on the disks.
In any case, within the clutch assembly is the place to look for the problem.
