rrlund
I'm pretty sure the ground's frozen up enough to pick corn. I plugged in the 2-105 this morning. I started it about 11 o'clock,pulled the wagons around and pumped up a tire,hooked up the PTO to the picker to make sure it would run,then put the tractor back in the toolshed. It's just too stinking miserable cold out there. If everything went OK and I could stay in the cab,fine and dandy,but if I had to get out and fix anything,this kind of cold is just too much.
It's supposed to be better Monday. If everything goes OK,I think I can get most of it in a good day. Tuesday doesn't look good,but after that it looks like upper 20s to low 30s days,20s overnight to freeze things back up again. I've been doing this stuff for too many years to think I need to be out there on a day like this.
