I need help identifying these things. 530ck case backhoe
I got this older 530ck and I've downloaded and purchased some manuals but I still can't find what these levers are for....should they be up or down, what are they for. How do u check oil levels for transmission. And hydraulics. And what kind of oil do u guys use for that stuff. And one last question...what kind kind of transmission do I have. I see there are like 4 different kinds for the 530ck....mine was made in 1959 so it must be one of the first ones
Hello caseuser welcome to YT! I assume you tried to
post a photo. Here is a quick rundown of the process.
Pictures post through the ..Browse or Choose files..
button just below where it says ..Upload
Photos/Videos.. down lower in the ..New post and reply
windows. I am adding a screen shot of how the button
looks on my iPhone. Clicking that will give you a choice
to select the file or folder the pictures are stored in on
your PC or phone. Then select the photo from the file
and ..Add.. it. They cannot be pasted into the text area
as a file. You may want to try to post only one photo
per reply and work your way up until you go over the
file size limitation.
I believe those that old were just one case like a farm tractor and would probably be a hytran type oil in the transmission /rearend like a tractor then the hydraulic was either in the loader frame or used the transmission case of the reservoir. As for the check location if the hydraulic oil is in the loader frame it probably has a check plug or site glass. The transmission case would be a check plug or more likely a dipstick for that since the loader frame would be kind of in the way for a check plug. Then they had a few options for drive train like shuttles and regular 4 speeds and I don't know what all for that part. A friend of dad's had an old 530 Looked like the 530 tractor from the 60's or similar .It had the 4 speed with a shuttle lever on the left side of the steering column.
