AnvilheadTX
Man I think I screwed up.... I have been rewiring my 8N in the evenings this week. It has been running funky and I decided to get rid of the rat"s nest that came with the tractor.
Monday - compression check - all four excellent!
Tuesday - I unbolted the wire loom to repalce it. A gusher of anti-freeze came out. I drained my radiator halfway and the the gusher ceased when I then took the bolts out all the way. I discovered that one of the bolts was very short....not broken or anything, just short. It would not even thread back in? I went to the tractor place and got a longer bolt. I actually got two new bolts to hold the new wire loom down. The heads were smaller than the original, but the older gentleman who helped me said they would be fine. This guys works on 8ns.
Tonight - finishing reqiuring - she cranked on the first push of the button. Idled fine. Then dyed when I tried to put the throttle up. I figured - carb adjustment - since I repalced the carb as well. Then I realized fluid was easing out around the bolt heads of the wire loom and I could see that I was loosing compression through these holes. It gets worse...I then started hearing odd "squeaking noises" and quickly shut it down. I thought at one point I even heard a rush of air as in compression rushing out of the tractor before I could reach for the key and the engine turned a few times.
Could anti-freeze have gotten into the oil? I thought.....and yep, it sure seems to have. I drained the tractor and the oil was very thin and had that anti-freeze smell to it.
What have I done? Can I have a cracked block? If so, would the tractor idle at all? Did I screw up the head gasket? Will the anti-freeze screw up the sleeves or once it is drained am I fine? I am still very new to this stuff so I appreciate any sincere thoughts.
