Geo-TH,In
A friend has a JD riding mower, LA 255 that needed a drive belt.
No listing for LA 255 on Amazon. The JD place in town wants $30 for the V pulley in the picture.
The idler pulleys used on this mower use metric bolts. All the pulleys pairs, one V and one Flat, I've ordered from
Amazon use 3/8 bolts.
I had to cut off the metric bolts only to find out the V idler pulley needs to be 3 inch diameter. The idler pulley sets listed on Amazon are all 3.5 inches. Grrrrrr
So, I ordered two 3 inch metal pulleys. One V and one Flat pulley. Metal pulleys should last a lifetime. Look at the flat pulley in the pic, you can see a hole in the plastic. Both pulleys need replaced.
Usually you bend a mower blade, not bend the mower deck. Somehow this deck was bent. I used a big hammer and washers to get the one spindle level again.
I wish I had said NO when he asked me to fix his mower! The underside of the mower needs a good cleaning. Crap falling in my face.
The idler arm was rusted in place too.
This is my last drive belt.
![cvphoto164189.jpg](https://www.yesterdaystractors.com/cvphotos/cvphoto164189.jpg)
