About month ago I asked the man who works for me if he changed the oil on the Farmall Super A. This tractor is used to cut about 7 acres each week, he said no he didn't have time. Last year when he took over using that tractor, the previous operator (who changed oil every 100 hours, washed the tractor every time he used it and would wax it once a month. He had to quite for medical reasons) told him it needed to be changed. I told him to change it and the filter. Now the oil pressure would drop to zero on idle. He said he found the oil outside the barn. When I drained the oil there was about a quart of water and three quarts of black oil, it was used oil. With suggestions from experts here, using a bearing separator, bearing puller and a lot of heat I was able to remove the pulley,to get it reground. THANK YOU I have a Ford 600 with a Woods RM mower. After about an hour of mowing the transmission locked up. I took the drain plug out to see what kind of surprise was inside. Found some gear parts, bearing parts and no oil. I refuse to give up. I have a Massey 135, with gas Perkins, in the barn that has bee setting for about 7 years. The clutch was froze to the flywheel. I got it loose by holding the clutch down and rocking the back wheel. MY LUCK IS CHANGING. Surprisingly it started but ran rough and backfiring. It would run on idle but wood backfire when the gas was advanced to the point the muffler blew apart. I put in a old condenser, USA, it ran better but still has some backfire when advance the gas. Any suggestions what it could be? I would like have it running before I take it to the farm, 250 miles from my house. I will bring back the Ford. I had to put new tires on my trailer, I love helping the economy. THANK YOU IN ADVANCE, Bill
with sugestions
with sugestions
