Ice on Carb
jc4598
After getting my Ford 641 started, it runs extremely rough andfrost(ice) begins forming on the outside of the carb where it bolts to the manifold. How do I solve this problem?
You don't. Carbs ice under the right conditions. The ice shouldn't hurt a thing. Both my 8N and IH M ice and run fine. If you have run problems look at fuel flow to the carb and out of the bowl.
Rick
That is just the normal thing a carb does till the engine get to the point that the manifold is warmed up. If it didn't do that then the carb would not be working as it should.
