ID these rims please
Jim.UT
My B-I-L has a Ford light industrial 4000 (gas, 4 cyl) with rotted rear rims. They are 24 but the connection between the rim and the center section doesn't look like anything I've seen on a Ford before. Can anyone ID these? We are going to remove the pie weights to get a better look at them in a couple of days.
If anyone has some good 24 rims available, let us know. He found one in a scrapyard 300 miles away but it's a loop rim and we're not sure this center will mate to it.
Click the link for the photos.
Thanks!
24 inch rims on Ford 4000
If you need to drive 300 miles for rims why not just get a pair of new ones from Heywheel and watch them deliver to the door. you will know they will fit and no fooling around. there will be freight in it but 300 miles and not fit is not free either. Heywheel is in KS so not as far as it might seem.
Hey Jim! Nice to see you posting again!
Yes, they look like standard double bevel rims to me too.
But, I don't see anything there that couldn't be fixed at home.
After a good cleaning, of course.
Weld a patch over the current valve stem location on the inside,
drill a new hole 180 degrees away from that and put it back together.
Much cheaper.
My thoughts exactly. By the time you drive 300 miles,pay for gas and motel room/meal,plus the time involved,plus the question if the parts will fit and are in good shape,you will be better off just biteing the bullet and ordering new.Yep,haveing to spend $600+ sucks,but that's just 'cost of ownership'.
