ID this 6x2 transmission
ptfarmer
Location
San Antonio, Tx
Picked up this Ford 6x2 transmission the other day, had a steering gear box on it like what you would find on a 4000.
Numbers on the left hand side of the bellhousing.
Numbers on the right hand side of the belhousing.
Had to take two pictures, and put them together so all the numbers are readable.
Without getting the books to be certain, I'd say it
was from a '72 2000. AFAIK, the 6-speed was only
used in the 2000 and 3000. Don't know why it would
has a 4000 style steering box on it.
b1012b
B10 (210) 2000 All purpose 1965-1975
1 ? Diesel
2 ? Trans PTO 540 rpm
B ? 6x2 speed manual (3x1 + hi/low)
2H14B = August 14,1972 3rd shift
C350184 is a 1972 serial number
JoeM has the numbers on the right side correct. The 2F28C on the other side is the assembly date for the transmission, which was June 28, 1972. Not sure what the AZ7005 is. The second number on that side has never been explained to me, and I have seen a number of different ones. Maybe a code for what internal parts it had in case they changed over time.
Only reason I can think that a transmission stamped with a 2000 ag chassis model number would have a single sided steering gear on top was that maybe it was swapped into a different tractor at some point. Maybe it was owned by Ultradog or his friend Kenny at some point. They are known to swap parts around between various models a lot. :D
Huh?
Me and Kenny swap parts?
Nah. :)
Someone might have swapped it into a 4000
with a bad SOS or even a 35,44,4500 with
Bad SOS or power reversing trans.
Well it's going into my 1971 4500 TLB that is all apart being rebuilt. I am going to have to drive it to different places, we have some hills that are kind of steep, and it may take a mile or two to reach the top. I don't want to drive those hills with the 4x4 with the torque converter transmission, my brother who used to work for a couple of Ford dealers say they are ok if you have a trailer to move them from place to place. I need to find a flywheel for it (it uses a single clutch, trans pto), since I don't need the pto that's no big deal.
(quoted from post at 14:31:48 06/17/17) What are build dates on engine,rear axle and on hyd resivour. They are stamped in plain sight.
Shaun, from his first post it sounds like he just bought the transmission with the steering gear on top, so I don't think that there are any other parts available to get codes off of.
Shaun Wallace is correct, I only got the transmission, and steering box. My 1971 4500 has the 3.3L, 201 cu in diesel, and looking at the online parts book its hard to figure out what flywheel I need. The one I think I have that uses the torque converter is part number C7NN6375C, the description throws me off because it says this 'Flywheel Assy., 11" Clutch, w/Torque Converter, NHNA, 3500, Years: 01-JUN-68-31-DEC-72', but I doesn't say if its for the 4500 also. If the 6x4 flywheel would work with the single clutch, and the 6x2 I sure would be interested in it.
The thread below about the 3600 starter
shows the good side of Ford. As RickB says,
one starter fits almost all diesels from
1965-99.
The bad side is that they made about a dozen
different flywheels for these tractors so
getting the right one can be a hair puller.
I would guess Shaun's unit will work tho.
By the way, if that transmission was in a
3500, 3550 or 4000 AP it will steer
backwards from what you need in your 4500.
The box is the same as is the sector shaft
but the worm gear is just the opposite.
(quoted from post at 00:09:54 06/18/17) Shaun Wallace is correct, I only got the transmission, and steering box. My 1971 4500 has the 3.3L, 201 cu in diesel, and looking at the online parts book its hard to figure out what flywheel I need. The one I think I have that uses the torque converter is part number C7NN6375C, the description throws me off because it says this 'Flywheel Assy., 11" Clutch, w/Torque Converter, NHNA, 3500, Years: 01-JUN-68-31-DEC-72', but I doesn't say if its for the 4500 also. If the 6x4 flywheel would work with the single clutch, and the 6x2 I sure would be interested in it.
Since that is a 6 speed from a 2000, I would think that you would want to go with a flywheel that was designed for a 2000 with a 6 speed, which would be part number E0NN6375LA, as that is listed for all 2000, 2110 and 2120 models from 01-OCT-69 on. And since that flywheel was only ever used on 2000 series models I would doubt that whatever flywheel is in your 4500 is a match. Then you would need a clutch assembly for a 2000 as well.
The flywheel for a 4500 with 6x4 manual reverser will work, it uses a 13" clutch that will hold up better than the smaller 11" 2000 clutch.
You need to check the splines on the input shaft to get the correct clutch disc, my 4500 has 15 spline input, most ag trans only have 10 or 11 spline similar to 13" clutches in later 3930-4630 tractors.
Actually any single disc flywheel for a 201 engine should work, you'll just need the match up the clutch disc and p plate to the proper dia and spline count
(quoted from post at 07:09:50 06/18/17)
That is good to hear, I know it has to be the 10, or 11 spline. I like 13" clutch better because it has a little more surface area than the 11" clutch. I'm currently taking the transmission apart (it had some water in it) so far only one of the rear bearings on the aux shaft is a little rough, I think I will replace them all (might as well while it will be apart) the gears look really good in it. Shaun Wallace send me an email [email protected] about the flywheel you have. Thank you everyone for the info, I greatly appreciate it.
