ID6 radiator
1960s
I have a 1948 international ID6 and it is always
leaking at the top of the radiator where the top
hose goes into the radiator. I have had it repaired
before but the leaking still continues. i have a
parts farmall M with a good radiator on it i was
wondering if the radiator off the M would work on
the ID6. any help appreciated thanks.
(quoted from post at 21:50:48 11/10/12) I have a 1948 international ID6 and it is always
I'm fairly sure the M radiator will physically fit. May or may not have the same capacity as the diesel radiator.
I have a WD-6 with a M radiator on it. The radiator dimensions are all the same. The only problem is that the M radiator side frames do not have the threaded nuts installed for mounting the WD-6 headlights. An ID-6 may be the same as a WD-6. I think the gas & diesel radiators were the same as well but I would have to verify part numbers to be sure.
