I'm working on my first restoration and it's a 1938 Allis Chalmers WC. It's missing a couple of parts in the cockpit and a few bolts here and there but it's mostly all there from what I can tell. When I got her home the other day there was a linkage rod (picture #1) laying on the deck of my trailer that I'm trying to figure out where it belongs.
I looked through every page of the shop and parts manuals and couldn't figure out where it goes. The second picture is of the area I believe it goes which is between the speed control lever and maybe the carburetor which is a Marvel-Schebler type. I'm figuring the carburetor has two possible places it could connect to which is the choke lever or throttle lever (don't know if that's what it's called). Another linkage rod that runs to the cockpit is already installed (pictures 3-5) to the throttle carb lever. The rod is a little too short to reach the carb choke lever. It doesn't make sense that it would attach to the carb's choke lever though - I'd think that one would go into the cockpit so you could control the choke. The last picture is of the front of the carb. There's an elbow on the inboard side with a threaded end that I thought might've fell off but the parts manual shows it exactly as it is on the tractor so I don't think that's the case. Not sure what that part is or does.
Anyway, if anyone can point me in the right direction I'd very much appreciate it. If I had a good, detailed picture of the left side of the engine I could probably figure it out, but this is all new to me it's like trying to back-engineer a UFO without having a fully assembled one you could look at. I've got some basic mechanical skills from rebuilding lawn mowers years ago but I'm just a beginner trainee when it comes to full size engines. Any help would be appreciated.
Thanks, Gene
Thanks, Gene
