The plate on the tank has NATL.BD.34175 Max WP 200 lbs 1952
there are other things one the plate
74405 1952
SH226HD194RH-ELL
HSB 74405
The plate on the compress says Size 3 3/8" bore
Duplex Compr
Serial number C8064A-17501 Min Speed 400 RPM
Plate on the motor has Peerless Electric Co
2 HP 1750 RPM 1 ph 115/230 volts 1 HR duty 60 cyv 26/13 amp
can't read the serial number because picture is blurry
Any idea where I can find parts. The large pulley has the center sections broken. Is this a good compressor and is it worth anything. It runs and pumps but slows down as it builds pressure. Right now it is wired for 115 volts but know it would work better on 230 volts. Have no idea how the mechanism on top of the pump works. There is a run that runs down the side and appears that the large pulley activates something. Any idea where I may find a manual or at least good pictures of this model.
74405 1952
SH226HD194RH-ELL
HSB 74405
Duplex Compr
