identify front bucket replace with front blade
Rkh
Can someone tell me brand of loader and there is a front blade that would connect to this?
Would like to have down pressure for front blade.
Wagner WM3 I believe. I think the down pressure would depend on the type of cylinders on loader. I'm sure others wiser then me will provide more info.
The bucket tilt cylinders are a custom modification, so any blade will have to be custom modified to fit.
So yeah, there are tons of blades available. Just get one the width and height you want, and modify it to fit.
About a three hour project, find you a 6 or 7 ft grader blade and weld on the eyes to match the loader. Notice that your loader has stops to prevent the bucket from coming back too far, will have to watch that on the blade. Do not want those bucket cylinders coming back and locking. You will be hard pressed to find a factor fit but any good welding shop could whip that out.
Agreed. The tilt cylinders and mounts are custom built.Farmer modification. So finding a 'factory' blade would be impossible.So you will need to modify an existing blade to fit. Also,the lift/boom cylinders are an issue. They could be only one way. In that case,no down pressure.However,the added weight of the loader,over the light weight of a 3point back blade,plus the fact you are pushing not pulling will give you an advantage.Weather or not you have down pressure.
