But the holes don't line up.Whatever these fit, has 5 "spokes" or "clamps" on the wheels.
David Brown was my first thought, as they are the right color, but all the David Brown wheel weights I can find on google are circular...
Really they'll fit whatever has the correct spacing for the four hole pattern in the middle, and with all the slots in the spokes, it looks like you could stack quite a pile on...
I really need to do some work... because I have zero dogs in this fight... but this was interesting enough to fuel some ADHD procrastination... or even amateur-crastination...What do these fit?
They are marked DB100. View attachment 87869
Speaking from experience the wheel weight bolt hole spacing on IH tractors with stamped steel wheel centers was different for each tire diameter. 24" was different from 26" was different from 28" was different from 30" was different from 34". Then the cast hub centers had a different spacing too. So it is is not out of the realm of possibility that David Brown had multiple different wheel weight spacings.It looks like it would fit the "power shift" style wheel centers perfectly. A 995 (or 1290) size would have 5 spokes to the rim, but only 4 holes for bolting on wheel weights. And there are notches out of the weights so you can adjust the wheel spacing while it has weights on. The last poster got a good picture of that style of wheel. But you said the holes don't line up for that, so.... any more ideas out there?
It didn't have "power adjust"/"spin out" wheels like the one pictured above right?We had a David Brown 1200 back home. The weights on that were a flat round disk.
I know very little about David Brown... but what I will say is... when I poked around to find a five spoke rear wheel hub... the David Brown 995 was about the only model that I could find with the exact configuration shown. Maybe the 885 as well.It didn't have "power adjust"/"spin out" wheels like the one pictured above right?
