Several weeks ago I was having an issue with loss of power. 8n would idle great but bog down when attempting to let clutch out to move and if trying to move up any small incline would lose power and die.
I took carb off and made sure it was clean. I had rebuilt it a couple month ago. everything looked good. Put it back on with same issues.
I read in the archives about resetting the main carb jet. I revved motor up turned main jet until it started to stumble and back it back slightly and it sounded better. I did not attempt to drive it to see if my adjustments helped at the time.
About a week later I was finally able to get back to tractor. I attempted to start it and ended up flooding it. (I do that often if I am not careful) I finally got it started up and now I cant get it to run over an idle. I can turn lever all the way up and see the linkage move at the governor too but no change or increase in power, still runs at idle. If I move lever toward actual idle it will try to die.
I also noticed that when lever is all the way or half way open it would backfire also.
I have encountered several issues from electrical to hydraulics and have been able to resolve them, but this has got me stumped.
Any help would be appreciated.
