Idle problems
hue1998
My new to me 2510 will not idle from running RPM unless I manually push the governor linkage toward the idle position to close the throttle plate. After reviewing the parts break out it appears I'm missing an additional arm and a spring for this assembly.
Could this cause the issues I'm seeing with my idle issue? Any suggestions for obtaining these parts? JD does not supply them any more.
This post was edited by hue1998 on 10/06/2022 at 08:48 am.
You found your problem. This arm and spring assembly pulls the governor shaft over center in idle
mode / position to close carburetor. Same parts used on many gas Dubuque tractors like the 2020 and
2030. Junk yards will have them. DW
(quoted from post at 18:51:24 10/06/22) You found your problem. This arm and spring assembly pulls the governor shaft over center in idle
Thanks. Appreciate the confirmation!
After posting this I also took a good look at the linkage parts and found the pivot link between the throttle plate and governor linkage was binding against the retaining clip. A little time with the grinder, a little grease, and everything is moving smooth now.
