DollarBill
I want my tractor to be like Dell's "eazy starting 6-volt 8n that idles at 435 rpm"
I'm putting the finishing touches on the engine rebuild and the only thing left is getting the idle right.
The best stable idle I can get is around 600 and the idle mixture screw is bottomed out - If you back out the idle mixture it dies.
I've overhauled the carburetor using the full kit making sure it was clean and tight - Soaked it overnight in carburetor cleaner, blew out and ran a tip cleaner through all the passages, verified jet sizes, float level everything that I can think of. Replaced the venturi. Top/bottom halves of carb mating surfaces are true.
If babied, it will get down to 550 but it sounds like it's gonna die any minute.
Exhaust smells very fat.
To show my determination, I bought a new, (looks like the original) made in the USA carburetor and after fiddling with the adjustments, the best it would do was 750 and it would eventually stumble and die. It actually ran better with the original one.
I've scoured the archives and can't find anything about poor idle quality.
What am I missing?
In case it matters, it's a 1950, 6 volt, pos ground, side mount timed at 4 BTDC.
What am I missing?
