Idler pulley
scotty11
Guys,
I have a RDTH60 Bush Hog brand finish mower. The front belt idler has shelled out. My question is, will I need to remove the plate/mount that gear box attaches to - Which is also what idler pulley shaft attaches to - in order to change idler pulley?
If anyone has any experience with this please let me know.
I almost forgot,the bad pulley is on the left or I guess drivers side, if this matters.
Thanks, Scotty
not famiiliar with your model, but most idler pulleys just either bolt on or have a ring that fits around the shaft and snaps in place in a groove. see if you can see a ring with two eyelets on it. you can get them off with a couple of old screw drivers that have been sharpened to a point, but they make a tool especailly for that ring.
John,
I looked at idler this morning and couldn"t see any snap rings. Looks like it"s held on by a bolt going into a sleeve that comes down from deck. I think I"ll need to pull gearbox deck because of clearance. I also found a diagram online and it doesn"t show any rings. At least as far as I can tell.
Thanks for reply, Scotty
did the bearings wear out in it or did the pulley just come apart where its welded to the hub. i have a ransome mower for my yard and it has sheared two of the pulleys off of the hub that attaces to the shaft the the blades attach to. i just weld them back on. line them up very carefully and tack it in three places around the broke joint before welding it up solid.
John,
It was completely shelled out. When I raised gear box deck the pulley fell off stud but the inner race stayed on. It went back on pretty easy I just had to pretty much remove everything to do it.
