ol' buster is at it again. this time just about stalling at idle. he runs good then sputters like he's trying to stall unless I rev it one notch, if I try to adjust the carb he just stalls. how can I get the idle faster without bending the throttle shaft to the governor rod (the only way that's worked so far). Buster has the 9N throttle and governor on the 8N engine if that matters. the screw behind the carb I think was for idle adjustment but I don't know how it works, the idle air mixture doesn't seem to do anything at all. It actually idles so slow the alternator wont even charge the battery (read on the amp meter) till I rev it up and the oil pressure sits at 8 on idle.
