ignition positive ground hook up
djbnsp
new to positive ground could use some help on my C how do you wire the ignition circut? tractor has coil & distributor any other wireing info on the rest of it apprecated almost done thanks
On battery ignition the coil terminal going to the points is same as battery ground. So in your case the + goes to the points, the - goes to the switch.
