Ignition Switch
300guy
Does anyone know where a person could find a good switch part number 361998R93?? Steiners has something to replace it but it needs spade terminals and I won't replace the ring terminals with spade. Plus it has some funky looking key with it. It fits a 300 Farmall.
If you can't find a good used you might be able to drill the spade terminal and attach your ring wire terminal wires. Parts Depot says no stock on your switch. I wonder if other mfg used that same switch?
I THINK that OLIVER used the same key switch as the KEY is the same and i have worked on a hand full of Oliver as my one friend has Olivers . Look and see what switch is used in the 1550 thru 2150's . NOW REMEMBER I SAID I THINK
I think this may be the right track. Everybody seems to have the same one or two pictures, so probably the same one or two switches. Somebody's (Worthington) description said spade connectors then something about included screws. It may be the spade connector has a hole that allows for attaching ring connectors, possibly requiring self-tapping screws. Or it could just be a bad description.
You might try calling a vendor and see if there is something to the spade plus screw indication.
Yeah that is the same funky looking switch everyone has for the 300. Not even sure it will fit right.
The switch has a 1 inch thread shaft which is another problem. I think I found one at O'Reily's that I can make work. Time will tell.
That Oliver 105232AS has ring terminals if you can find an old stock or good used . Not certain it fits the hole.
A-C. 235785, 70235785, 229201, 234356, 233320, 231705, 230163
Case – D75657, L17820, A11373
Cockshutt – T18021B
IHC/Farmall – 300557r91, 1116629, 361998r93
Minneapolis Moline – 20-7101027
Oliver – K7354B, 100423ASA, 105232AS
White – 20-7101027, 721146A, 611064AS
