ignition timing
Since he is running LP head on a gas, and I am assuming he is running gas, would you not have to time it to some new spec. Should/might ping on gas with higher compression, if using LP spec. LP is higher octane rating is it not?
Retard timing if you hear it ping!
Roger in Iowa
You are going to have to feel out the timing. Advance it until it pings accerating under full load and back it off a but until it never pings. That's as much advance as you can use. At part trottle it can handle more advance and needs it for economy but without a vacuum advance you have to set it at full throttle acceleration full load and take the poorer performance at part throttle.
Gerald J.
I went from a multifuel head (4-1) to an LP head (8-1) on my case LA I run it at 30 degrees at full Advance with no trouble.
Walt
