IH 1086 digital data center
I recently bought a Int 1086...serial number shows it to be a 1978. It has a digital data center that has a switch that will move around to RPM, MPH, 540 PTO and 1000PTO. What I have read so far is there is an older version and a newer touch screen data center that was put on these tractors.
I am not getting any lights out of the data center....I replaced all of the fuses in the kick out panel and found the inline fuse and replaced it. All of the wires seem in good shape and traced from the harness that plugs in to the data center down to the fuse panel.
In looking at the harness....the are several numbers on both the harness and the back of data center. But not sure what number represents what.
Once I replaced the fuses...the gauges on the other side of the dash began to work.....Oil Pressure gauge....voltgage gauge....temp gauge...gas gauge is not working the needle just sits there and shakes on the E side of the gauge.
I have not pulled out the RPM transcender yet to see if it is dirty..but I am assuming..if wires are good..fuses are now good...tractor fire up and have power to my radio...ac fan unit..windshield wiper, horn....then would I then assume the data center is just bad? Is there a way to check it out or a better way to determine which part of the harness is to be hot or not?
Fairly new in getting back into farming....so my terminology may not be spot on..but any ideas or questions and I will respond.
You aren't getting any help here on the IH board so i will add a little more to what i said on the tractor talk site. Like I said there is an oil pressure operated switch that turns on the digital tach on the early 1086 like yours and mine. Mine was bought new Jan 31 of 78. Look for that switch on the engine block ahead of the lower right cab window. It looks like a regular electric oil pressure sender. The hot wire feeding that switch is hot all the time unless someone changed it to being hot only when the switch is turned on. Take your test light and check for juice in one of the wires on that switch. If nothing, turn on the key and check it again, if still nothing you will have to trace that wire. I have a factory service manual out in the shop it might have a wiring diagram.
Will check for it soon.
Having trouble posting pics if the diagrams. Will try one more time
It looks like the pics are for the newer data center but I have a hunch both are wired basically the same except the new one has a few more wires going to it, one for exhaust temp and alarm which the old data center does not have.
Thanks for the input...I will look at the tractor when I go to the farm this weekend....
I found what I believe is the RPM transcender unit on the right side in front of window. Would this electric oil sender unit be close to this? Since I am not there everyday...I should take pictures of both sides of motor so I can see things when I am at home trying to figure things out.
I will say on my harness the bullets I have are 1 2 3 4 6 7 10 12 13
I need to give this tractor a good power washing! The switch will be where the small black hose comes out of the block next to the oil filter base. I removed the switch and screwed in a hose that goes to a manual oil pressure gauge. Like what was mentioned the gauges are iffy at best.
