IH 1086 loader valve plumbing
Zeb Klein
I am looking for help/ideas on how to plumb my IH2350 loader onto the IH 1086 tractor. Currently, I have both hydraulic remotes tied up. I am wanting to put a joystick in the cab and the hydaulic valve outside the cab. Any ideas on how to plumb this into the tractor without tying up both rear remotes? Where would any of you guys go to buy the joystick and valve? Thanks in advance for any advice you all might have.
Zeb
I use one set of remotes on my 1066 for the loader joystick. Then you still have a set of remotes for other options.
Surplus center is the best place i've found for joysticks etc. You need the hyd. valve to fo under the cab and a wired joystick for in the cab. They have that set up in stock. hope this helps. Kent
My 886 is plumbed separate. There is a plug in the end of the remote stack under the cab (under the controls by the fender well). A line runs from there to the loader joystick control. The outlet runs over to the bottom of the MCV cover on the shifter side of the transmission behind the battery. My only complaint is that they weren't careful when they ran the return line and it has been rubbed by the gear (1-4) arm when you put it in first. Let me know if you need pics.
