My IH 1600 Loadstar truck sat for a couple years before I sent it to the shop for repairs, before it left here the 2 speed worked perfect, but now something isn't right with it, if I am in High range and push the button down for Low range the amp gauge goes in the negative a good ways and the fuse will blow. If i leave it in High range everything is fine, I checked the wires and could not find anything bad, I tried another 2 speed switch at the gear shift but that did not help any. Normally with just the key switch on you can hear it changing back at the rear axle but now I can't hear a thing. Anyone on here ever seen this before?? Only thing left to check is the 2 speed itself I'm thinking?
