ih 1a, what do i have
steve byrd
tractor is yellow, has square front axle, has foot accelerator, ser#1aa148308m model 1a. does anyone know if this is a industrial or utility. nc dot used it to mow right of ways.
Are you sure that it doesn't say IAA 148308?
If it does, it would be a 1946 International A, which is the "Industrial" version of a Farmall A. The only real difference between the International and Farmall versions is the front axle and the foot throttle.
Yep that's what you've got. The axle tube and the foot feed are the quickest clues. Depending on who hads done what over the yers, it would originally have had International hood decals and grille emblem, rather than Farmall in those places.
The prefix on your serial# is 1AA (there's some discussion as to whether that is actually 1AA or IAA -- I'm reading from Guy Fay's Data Book here), indicating it was an International as opposed to a Farmall, which would have started with FAA. Apart from the prefix, the 1/IAAs shared the same serial # sequence with the FAAs, which would make yours a '46. If the serial # on the motor matches the one on your ser# plate, you have the original motor, as well.
thanks dave for correcting the ser# and the other useful info. you guys are real champs. it does have the orginal engine.
