IH 2250 loader cylinder leak
7lazy77
I have been putting off repairing some leaks in both lift cylinders. They weren't major leaks, but finally had enough & want to fix them. Do I have to do a complete rebuild, or would just replacing the seals be enough? There are no pits in the rods.
I was also considering repairing the two bucket cylinders as well, since I am already spilling hy-trans fluid all over!
The seal kits for these cylinders are $$$ from Case IH. You have to know what cylinder you have to because they used many different kinds. There should be a number stamped on them. Hope your rods are in good shape because you can can’t get them through Case IH any more. I think the only thing available for parts on these loaders is the seal kits.
