Well, things were going well until two days ago and now the hydraulics aren't working at all.
I started it up to do some bush-hogging, and I started noticing the edge of the hog was dragging the ground. I raised it up and seemed to be skipping like air pulsing. It stopped when I quit raising, but then it started dragging later and the 3pt had dropped to its lowest level and didn't move.
This happened before, and I flushed the hydraulic lines and filter multiple times. I ended up putting a replacement hydraulic pump on it and all seems great until this weekend.
Upon closer inspection it seems the pump isn't cycling now. I drained the hydraulic fluid and pulled the suction filter again to check out. The fluid looked fine and there was nothing in the filter.
I refilled anyway to try and nothing. It seems the new replacement pump has gone bad. With it stated and me watching it doesn't appear fluid is circulating.
I started experiencing the same issue with the old pump, but it now seems that pump may have not been the issue completely as I thought.
Anything I've missed?
