Robert C in Albuq.NM
Thanks in advance for any advise , I have a 300U that doesn t steer correctly, it is hydro powered so I don t know if it is the power steering pump or the steering colum that needs repair. Can a manual steering unit be installed and will it work in the space or do I need to keep the power assist steering and work out the problem.
when I turn to the right the left wheel turnsand the right just drags and when I turn the opposite the left wheel drags. I checked the fluid levels and the steering unit was dry, so i filled it and lifted frontend off ground and turned the wheels back and forth , still had the drag problem, and about an hr later all the fluid was leaking onto the ground so it looks like all the seals are bad. If the rear hyd lift works , does that mean the hyd. pump is good? all hyd. run off the same pump and hyd tank under the seat. What am I not seeing?? Thanks for any ideas or knowledge you can give, email direct at [email protected]. Thanks again, tractor newby out.
