IH 330 Utility coil question
tarheel65
Three times I have been mowing and the tractor dies after about 30 minutes and won't start. Sits overnight in the field and starts the next day. Thought it might be the coil, so ordered a new one and when I put it on, the tractor won't start. This is a positive ground 6 volt system. Put the old one on and the tractor starts right up. With the new one on, I am getting a spark when I pull a plug out and turn the engine over but it won't start. If the new coil is bad, would I still get a spark at the plugs? Also, when I took the old coil off, I noticed Use external resistance stamped on the case. There is no external resistance wired in the ignition system. Do I need that?
Just to make my comment short and sweet,my B acted a little that way.mine would stop with in three minutes and coil was so hot i couldn't put my hand on it for very long. Long story short my voltage regulator was shot !!!!
Sounds like the new coil is a 12 volt coil with no resister needed so on 6 volts it will not work. You need a coil that is a true 6 volt coil with around 1.5 ohm resistance
DID you get a 6v coil people sure have problems it seems if you have a 6v system get a 6v coil and if you have 12v get a 12v coil no need for resistors ect either a 6v system or 12v
External resistance is for 12 volt system. You can use it without resistor on 6 volt. It should be a 1 1/2 ohm coil
Regardless of what is stamped on the coil you need one with about 1 1/2 ohms across the + and- posts of the coil. Check your new coil resistance, new one could be mismarked
