ih 3444 TLB hydraulic problem
subs1000w
It runs and opperates great most of the time but intermittenly it looses hydraulic pressure aspecially when opperating on hills, right now it will start and i can get the loader to work alittle but nothing on the backhoe and power steering is not working consistently the steering wheels spins with little resistance, theres no hydraulic resovour under the hood so i assume it shares fluid with the trans, i have checked the trans dipstick and its full, im guessing its a leak on the suctions side, any suggestions on troubleshooting
check the filter. found ground up 2x4 in mine. Have a brand new hydraulic pump if you need it.
the transmission and all hydraulic fluids are supplied by the transmission case. Dipstick right by shifter.
i checked the filter and im unfamilar with this setup but does the filter just loosly slide into the housing it didnt seem secure matbe its the wrong filter, and also does the ststem have to be bleed/primed once opened, i also checked the fittings/couplings with shaving cleam to see if it sucked any in and didnt find anything, i would assume the pumps are fine since nothing is working and there are 2 pumps, any more suggestions on what to check or replace next would be great, i would like to replace the donut gasket on the filter cap if anyone knows the part number thanks
