IH 350 utility
I have had this tractor for years now and when I am working with it in after about a hr the gas in the tank starts to boil to the point it starts to vapor lock I think. For it will start to run ruff
and I loosened the cap and let the pressure out it run ok
And yes there is a vent hole on the gas cap and yes there is a stream of pressure coming out of it.There have been times when I have loosened the gas cap and almost blew off like a radiator cap. I feel like this should not be normal. It has been like this since I owned for about 20 years
the gas cap should have 2 holes to be vented right, not one hole. you can get a free correct gas cap by contacting https://www.ihgascap.com/
Truth! they are a poor design with the tank so close to,and above the engine. Using aluminum foil based insulation behind the engine that blocks off the heat to the tank is a 50% solution and reduces the heat transfer to the fuel. Todays fuel is controlled as to boiling point, but winter fuel is very easily boiled. I own a 350 and have had it do that. Mine has the foil. Don't use plastic based reflective stuff, it needs to not melt. Jim
Years ago I read someplace where someone made a pusher fan blade to push the heat from radiator out instead of pulling it back into the gas tank.
Anyone know anything about pusher fan blades?
That is interesting- I have a 300u, basically the same tractor, and I have used it since me and it were both young. I have worked it pretty hard in hot weather and it never has boiled the fuel, even when I let the radiator get partly blocked. It still has the original gas cap which has a ding in it from a bush hog blade.
I do remember having our 8n ford boiling the fuel, after plowing along a river bottom on a very hot day back when I was about 10-12yrs old. That gas tank sets directly above the engine. Mark.
Older Cat dozers had a fan that was reversible- you just flipped the blades with a wrench, I believe. They blew forward normally-reverse for cold weather to warm the operator.
International 3088s and 5088s (and others in that series I guess) were designed to suck the heat forward thru the radiator. The fan blade shaft goes thru the center of the radiator and blows forward. The shrouding is designed with a screen in the top of the hood for inlet air. Cooler for the operator. Pretty neat design idea- just harder to replace the water pump or radiator! Mark.
The only way to make a fan push rather than pull is to rotate it the opposite way. Example: a piece of all thread rod with right hand threads has right hand threads from both ends. Jim
