(quoted from post at 11:16:40 01/18/23) You bought a tractor with a continental diesel which parts are expensive to find and a IH utility tractor notorious for steering problems when a loader is attached without it running to try out. You don't
mention what you paid for it so you might of done OK but maybe not. They are a nice tractor when everything is OK so I hope you did OK. I have a 300U gas which had a loader when I bought it and it had major
steering problems. Didn't catch if you have power steering. If so that helps but if not they are a hard steering tractor without a loader.
The guy is selling it for his FIL who is an assisted living place. He didnt know much other than it last ran two years ago. I go get it friday. I should call him back and ask about the power steering. The price is cheap enough so i should be ok. I had a B 414 a few years ago and it turned out to be a money maker so keeping my fingers crossed(quoted from post at 12:03:17 01/18/23) If it doesn't need a lot of work I would say that's a great price. I've seen the gas version of the tractor in reasonably good shape go for couple of grand. Let us know what you find out when you get it home.
Did the guy tell you anything about it when you talked to him? My dad had the Farmall version of the 350 diesel and it had a lot of power for its size. That tractor got worked hard by us and the previous owner
and one day it broke the crank shaft. When the mechanic took it apart he found the head cracked. This was back in the mid 60's.
Thanks for info Janicholson... I'm pretty new to IH tractors so could explain the Torque amplifier and how can you tell this tractor has that?(quoted from post at 18:38:42 01/18/23) I also notice that it does not have a PTO. It does have a Torque Amplifier (TA) which makes it a 10 speed with 2 reverse. and clutchless shifting from direct to low and back to direct. IIRC this means it could have a Live PTO added from a donor Farmall or International 300 or 350 Jim
(quoted from post at 11:07:16 01/19/23) The entire Live PTO unit (used) must be purchased. This includes The drive shaft (internal) and the operating handle and linkages. A new gasket where the plate is now located on the back of the final drive housing. I do not know what the serial number codes are on the machine they are numbers and or letters after the serial number. Because it has a TA, it is more likely to accept a Live PTO than not. The S in the code should allow the Live PTO and TA. Jim
(quoted from post at 08:33:41 01/19/23)
I assume that is the battery box but not sure.. haven't seen it in person yet. I go get it tomorrow...driving 115 miles one way over a mountain pass
